Old 03-15-2007, 05:32 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Air conditioner blowing hot air
Today, i got my windows tinted and those of you who have ever got windows tinted, they know that you cant roll down the windows for about 48hrs. I live in AZ and it is about 90 degrees out. I turned ma A/c on , but it only blew hot air. I tried turning it on and off and enonomy mode, but it still blew hot air. I was frying my ying yangs off for 45 minutes!! Any ideas on what maybe the cause?
Thnx
Old 03-15-2007, 05:34 PM
DarknessofDeath's Avatar
DarknessofDeath DarknessofDeath is offline
Inhabitant of Darkness
compressor dead?
condensor leak?
not enough freon...some other leak in the system
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 03-15-2007, 06:20 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
First check the compressor.
Compressor NOT working: a)low refrigerant. b)low pressure safety switch triggered. c) blown fuse for the compressor's clutch.
d) compressor has seized. e) loose belts.
Compressor WORKING: a)defective Expansion valve. b) low pressure. c)obstruction in the evaporator or condenser.
d)dirty coils.
Old 03-15-2007, 06:46 PM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
there is a how thats near the radiators drivers side it goes from the compressor to the condensor its a common hose that breaks i think its the main pressure hose
it runs around 140.00$
what ever you do do not get the freeze 12 freon!!! its a suplements to the r12 but it suxs, find a local a/c shop and replace it with the r-12
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 03-16-2007, 06:40 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Hope it's not doing what mine started doing. It blows heated hot air on all temp settings, including vent. I'm dreading taking the dash apart to see if the mixing door is jammed or the motor not working.
The last time it was recharged, they did put in the Freeze 12 stuff. What is the problem with it?
Gene
Gene and Ben
Old 03-16-2007, 12:07 PM
VICSVX's Avatar
Never Forget
hmm, i'll look into what all you said. i'll keep you updated on what i checked ect.
thnx
