Overheating Continues
After my Friday track day, I though I had my overheating problems fixed, but a new gremlin has arisen to give me grief. I noticed it first on Sunday. Went to the car wash, and the temperature, right after starting, with only in town driving, rose right up to the red bar. After a little bit, it dropped down to mid level, stayed there, and then a little while later rose up to the red line. Putting the AC on and off seemed to have some effect, but its not consistent. Sometimes, turning the AC off or on would initiate a change, other times not. All of this is occuring at very low rev's, in-town, modest acceleration. The fans are running.
I read all of the threads about head gasket blow-by, boiling the coolant. Thought that might apply because of my experience at the track. But, this isn't consistent with that. It is too off and on. Normal, then hot, then back to normal again. No in-between and not linked to accelerator use. I'm betting on a balky thermostat. Have ordered one, will change it, but will get the HC coolant test at the same time. Any thoughts?
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
I think that you might have a semi-block in one of the coolant lines. That would account for the pegging of the redline, only to come back to the middle again.
mine was pretty inconsistent with a bad head gasket. some days I had no problem. some I overheated quickly. the only thing that was consistent is that it got worse over time.
I would agree that it sounds like a sticky thermostat. Mine did that when my thermostat was heading out. Replacing it fixed the problem right away.
Change the termostat first... but he also could be facing a water pump failure or a bad Rad.
Mine had no oil/coolant mixing or loss. I was just overheating the coolant from blow by and that was causing boil over into the expansion tank. But - if I drove it easy it could heat up and cool down. Running the heat on high would usually keep it cool. It wouldn't stay overheated unless I beat on it or the coolant got low. Alot of times I could take long highway trips with no problem and then when I stopped or slowed down for traffic the overheating started.
