View Poll Results: What clutch are you using?
Stock cable operated 0 0%
Aftermarket cable operated 1 20.00%
Stock hydrolic operated 1 20.00%
Aftermarket hydrolic operated 3 60.00%
Voters: 5. You may not vote on this poll
Old 09-24-2004, 01:43 PM
Earthworm's Avatar
Meow!
Clutch Curiosity
Just want to know what all the 5 speeders are using for a clutch.
Old 09-24-2004, 08:10 PM
Subafreak's Avatar
Superbeast
I got an ATC that seams to handel drag launches well. (better than the tranny)
Not sure what I'm gonna run with the six speed yet
Old 09-25-2004, 09:16 AM
mbtoloczko's Avatar
sans SVX
Exedy 13.5 lb flywheel, Exedy Sport clutch disk (organic) and pressure plate. Worked well until I smoked it once in a drag launch. Now it shudders badly in the morning. Going to try an ACT flywheel and clutch next time.
Mychailo
Visit my locker
Old 09-27-2004, 01:21 PM
Earthworm's Avatar
Meow!
Mine used to shudder every once in a while (in the morning as well).
Mine slipped once during an autox (Sept 18/19) and hasn't shuddered since
