Mystery Part
In the process of changing out my PCV valve (can't get the d@mn thing off) I found this laying on top of the engine below and behind the valve. What is it?
1997 Bordeaux Pearl LSi ~45K |
Man, I have no idea. I've not seen anything like that. Perhaps it was a part from another car that a tech dropped while working on the SVX in its previous life. Anyone else have a clue?
It covers the access port on EJ/EG/EZ engines.
dcb |
a bicycle seat
What usually happens is that the little tabs that hold that piece in place break off over time and the piece falls off.
You will find where it goes if you look at the top-back of the engine on the passenger side. Through the hole you will see the gear of the torque converter. Your best bet is to put a bead of silicone on it before putting it back then allow it to sit overnight.
Isn't it kinda odd where I found it? Seems like it woulda fallen on through the engine compartment.
HA! that's what that was? i found one of those when i took out my engine awhile back... i think i might have kept it "just in case"
I found mine there as well. I eventually bought a new one. That's how I found out the tabs were broken off my old one.
Well it's actually only to allow access to the flexplate/torque converter. You shouldn't be doing anything to the flywheel through the access port.
Unless you are pulling the engine.
Why do you need to get into the accessport on a manual if you are pulling the engine?
So there's a cover on the top of the tranny and a gaping hole on the bottom. Figures...
The port it on the engine. What figures?
