Removing Glove Box
Can someone please either give my detailed instructions (preferably including pictures) on how to remove the glove box or point me to somewhere in the service manual that describes the procedure? I tried today and couldn't do it. I removes the 5 large screws, the three small ones across the back, the three across the top, the 2 on either side and the 3 that hold the door on. The box was loose, but I could not remove it. I could not find any more screws to remove, but I figure there must be something still holding it.
Thanks. |
Hope this helps:
Thanks, Beav, but I have that picture. I still can't see what else I need to do to get the box out. Do I need to remove the striker (#12 in the picture)? Do I need to remove the bracket (#13 in the picture)?
As I mentioned, I removed 15 screws and bolts and couldn't see what was holding it from coming out. I couldn't find instruction anywhere in the 6 volumes of the service manual. |
Yank on it harder. Some times the knuckle dragging tree dweller method is the only one that works
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
No for #12 and #13. Just remember there's at least 15 bolts/screws that need to come out.
It's a little tough to get out. Just make sure you get ALL the screws out.
Whenever I take apart something with lots of different screws, I put them all in numbered dixie cups, and make a simple drawing with numbers ref. which dixie cup. A little off topic, but true story, I took my TCU out instead of the security module, which was the goal, when I removed my glove box. I then wondered why the car would not move from park. Oops. No permanent damage right? |
Greggbzz - isn't the TCU under the steering wheel not behind the glove box? |
