Old 01-04-2017, 11:01 AM
urabus92 urabus92 is offline
Unknown electrical problem please help!
Hello I got a 92 Subaru svx LSI pearlie and now it is draining power after about a day of none use. I have got 3 battery's 3 different alternators and I'm at wit's end I know it has a bad drivers side seat motor will not move forward but will move back of the seat. I'm not experienced in electrical problem and I really and at a loss as please help.
Old 01-04-2017, 12:09 PM
Re: Unknown electrical problem please help!
You have what's known as a parasitic draw. Something is using power when the car is turned off.
A common cause is a short in the wires on the vanity mirror lights on the sun visors.
I had the trunk light staying on draining mine. I only found it when I had the back seat folded down and noticed the light stayed on when the trunk was shut.
My '92 has a drain now. I disconnect the battery at night to avoid killing my battery until I track down the problem.
Old 01-04-2017, 01:18 PM
OK but it is also flashing power 4 times slow then then 16 fast blinks will happen when I turn it on but now the ldel is jumping about 2 grand then powers off
Old 01-04-2017, 10:18 PM
Check with Tom Krynock "svxfiles", the resident SVXpert mechanic, right across the river in Wiley Ford, WV. Less than 5 miles away.
http://www.svxfiles.com/
Tags
electrical drain
