IRQL_NOT_LESS_THAN_OR_EQUAL wtf!!??
im getting this error IRQL_NOT_LESS_THAN_OR_EQUAL with a nice side of blue screen death. ive looked on the tech forums with little help. whats going on with my box.
See, that's the beauty of Microsoft products. They provide super clear descriptions of the problems. Bill and team were kind enough to provide a message to you, prior to death, that expalined everything. First, you must understand that your IRQL is most certainly not, less than, or even equal. From there, the fix should be quite simple.
Sorry for the humor. I know this could be a very trying situation. If all else fails, are you able to boot into safe mode, use System Restore and then restore to like yesterday? Of course, you might wnat to backup data if you can. Of course, this all leads to a reformat, basically. Best of luck.
Eric 1994 Bordeaux Pearl SVX LSi "The SVX — Where, they wondered, do you put the kayak?" |
Google is your friend
Andy ------------------------------------------------------------------------------------ If I would be a young man again and had to decide how to make my living, I would not try to become a scientist or scholar or teacher. I would rather choose to be a plumber or a peddler in the hope to find that modest degree of independence still available under present circumstances. -- Albert Einstein, The Reporter, November 18 1954 |
I find this error most common to be a hardware/driver malfunction.
Have you recently upgraded any hardware or drivers?
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
the techie at the geek squad said might be a ram problem. it started alot shortly after the last windows update but i saw it first recently after installing the nvidia gforce 6800 gt pcie (used to be ati x700 pcie). but i have had this error a few times in the past after building the machine. it magicly went away and now its back. because of the conflicts im having with the gpu and motherboard im replacing my motherboard and cpu to an abit fatality and amd 64 3800+ so i hope i dont have this problem again. but i might and it would be nice to know how to fix it. im useing kingston hyper x ddr 400 512 x2 ram set and i plan to cary it over to the next setup.
oh and im water cooling it with a koolance exos. Last edited by Matthewmongan; 02-24-2005 at 04:30 PM. |
Could be RAM as RAM is hardware. But generally the BIOS should be able to detect a bad RAM chip if it does a complete seek. Try it by disabling any kind of "fast boot sequence."
I'd put the blame on the PCI-Express Bus you're using. Keep in mind PCIE is pretty new so check online to see if anyone else has the same issues with ur hardware combinations. I was going to also say that it might be a heat issue, but seems like you have that covered. Be sure all the fans are working, all the chips/cards are seated properly (take em out and put em back in) Have you tried a fresh install of Windows? I've had errors that would just not go away. I had a constant "bug check" error (basically fatal exception) that would restart the computer at random. I could not fix it at all, but a fresh install of XP seemed to do the trick. ....Oddly enough usually a fresh install works - When did u do your windows install? Good luck - no one likes the BSOD
im hoping the fresh start works, im getting the new equipment in saturday but i wont get the mounting bracket for the cpu cooler till mid next week i hope this works because i got alot of audio editing to do.
I also recommend a clean install of Windows. I've had nothing but bad luck going from any ATI video card to any nVidia card (or the other way around).
It took us a week to figure out that my friends ram chip went bad. no blue screen just total lockage. Many scans and such no error messages
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
yeah ive run a hole bunch of scanns. fortunately kingston has a lifetime warinty so im going to send the set back to new egg in a week or so. its just a pita with the down time of waiting for them to send me another set.
2. If you're going to upgrade the mainboard, memory, and CPU, it's a good idea to reinstall the OS from scratch. Some updates for Windows causes problems with driver installs. 3. Since you overclock your computer, I'd say check out those tin foils that help the memory transfer heat. Just because it's water cooled doesn't mean the memory's cool enough. Many people had problems with those little memory heatsinks. 4. Maybe your board's fried. It's a common problem for people who overclock. Changing your board and CPU might fix it. |
