Old 08-10-2009, 10:20 AM
sicksubie's Avatar
Fiberglass intakes
Just thought I would share what I have been working on here now that I no longer need a MAF... Pics will be put up tonight when I get home from work.. Lets just say that foam pool noodles have now found a new use
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 08-10-2009, 04:12 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: Fiberglass intakes
I've been thinking about this for some time now. I can't wait to see what you come up with. It's got to be better than metal for thermal protection. I believe acetone will eat away pool noodles without harming a fiberglass mold.
Wanted: Steering Wheel
Old 08-10-2009, 04:16 PM
the_paynter the_paynter is offline
I always assumed that fiberglass wouldn't make a good intake, seeing as how it is an insulator. But I guess people do make carbon fiber ones?
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 08-10-2009, 05:28 PM
michael's Avatar
What Potholes ???
ABS plastic would be ideal, but how can you work with that DIY.
Old 08-10-2009, 06:49 PM
sicksubie's Avatar
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-11-2009, 01:20 AM
Gamesy's Avatar
Gamesy Gamesy is offline
are you running this from an intercooler or just have 2 separate intakes?
Old 08-11-2009, 06:52 AM
sicksubie's Avatar
Just two separate intakes...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-11-2009, 07:44 AM
ridered777's Avatar
ridered777 ridered777 is offline
Finally HAS a 3rd pedal!!
Send a message via AIM to ridered777 Send a message via MSN to ridered777 Send a message via Yahoo to ridered777
How are you going to run this dual setup without 2 MAF's?
Is this an option only for Hydra'd SVX's?
-Craig
94 LSi 5spd Barcelona Red, 14Xk miles.
Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior.
(up next) Full cage, fuel cell, 327 swap
Old 08-11-2009, 08:34 AM
sicksubie's Avatar
The joys of a Hydra...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-11-2009, 01:19 PM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Interesting stuff.
Where can I get me a cool oil cap like that?
Old 08-11-2009, 02:13 PM
sicksubie's Avatar
Ebay or Nasioc..
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-11-2009, 02:31 PM
hydra can read from a MAP sensor instead of a MAF, eliminating the need for that pesky MAF. I had a hydra on my old widebody GC8 and ran a MAP instead.
Intake is turning out great... how do u get the pool noodle out after?
Old 08-11-2009, 02:54 PM
sicksubie's Avatar
I will cut it on each side with a dremel and then smooth out the inside as much as possible before epoxying it back together
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-11-2009, 03:00 PM
awesome... looking forward to seeing it done!
Old 08-11-2009, 04:50 PM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Curious...can you just melt out the 'pool noodle' afterwards? A lot of people making one-off parts use a foam core, form the composite part around it w/epoxy and fiberglass, then melt out the foam core w/acetone or similar solvents. This way you'd have a very strong part with no seams to potentially fail.
Bob Légère
EG33 Impreza tweaks
