Old 04-06-2012, 09:48 AM
World's tiniest Operational V-12 diesel engine
OPERATIONAL V-12 DIESEL ENGINE THAT FITS IN THE PALM OF YOUR HAND.
this guy has the Patience of a Saint and extremely skillful.
This is not your modern CNC technology; this guy made everything at home on his lathe and drill press. Took 1220 hours (a year and a half?) to make the 261 pieces needed. Note the end-loaded crankshaft into the block (like an Offy), 12 individual cylinder heads, TINY rods and pistons, dual "underhead" cams with pushrods to rockers in the heads.
He did break-in using an electric drill driving the crankshaft!
Even if you're not an engineer, you'll love this! Truly fascinating to watch it all come together.
Old 04-06-2012, 11:21 AM
Re: World's tiniest Operational V-12 diesel engine
Does this one actually runon file or compressed air? I have see about 4 of them. Most use compressed air. Sorry I did not have time to watch the entire video
Old 04-06-2012, 12:12 PM
Green1995SVX's Avatar
That is absolutely incredible!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-06-2012, 12:21 PM
I literally envy people who can achieve this, amazing!
Old 04-06-2012, 12:49 PM
Yea, that is really awesome. One part I don't quite understand - how is the fuel delivered?
Old 04-06-2012, 01:35 PM
92 SVX 92 SVX is offline
external pump from the looks of it.
I wonder about oil I didnt see any sort of oil pan and while he was using the drill how could the bearings take that without problems.
Old 04-06-2012, 01:53 PM
No fuel it is running on compresses air . Parts missing is ignition and fule pump, carburation. Only machanical parts. There are others that people have built ( Chevy V8 is another ) It runs similar to the way a sewing machine runs, so no heat only needs oil.
Old 04-06-2012, 02:39 PM
You mean the pump looking thing he's putting together at ~7:23? That's the only think I can think.
I don't think there are bearings, I think the crank is in direct contact with the rods.
No, it's diesel. It doesn't need any ignition because it's diesel. It's not running on compressed air.
Old 04-06-2012, 04:24 PM
yes, that does look like a injection pump, run off the cams or crank cant tell which but it would be a centrifugal pump of some sort then that other piece seems to go to a fuel rail.
and there is probably some pump pushing fuel up to that injection pump. Most diesels I have seen have 2 fuel pumps a lower pressure "lift" pump that keeps fuel fed to the high pressure "injection" pump.
Old 04-06-2012, 04:33 PM
ok after looking over the description at youtube this looks like it runs on compressed air.
Old 04-06-2012, 07:54 PM
Some other motors
http://www.google.com/search?q=small...&client=safari
