Old 11-09-2005, 07:51 PM
The Molinator
Bearing, Axle....OR ...???
I'm getting a bearing type noise....apparently in right front area. I can't remember what the axle sounded like when going before [same right front wheel]? Is there a way to delineate between the wheel bearing and the axle up front?
THANKS for your input!
Jim
Old 11-09-2005, 09:37 PM
svxsubaru1's Avatar
A bad axel should make a poping/clicking noise, and a bearing can make a continues grinding/roar.
92 Honda CBR 600
95 Miata
Old 11-09-2005, 09:38 PM
Manarius's Avatar
Manarius Manarius is offline
Here's a grind for you:
http://media.putfile.com/Really-a-bearing
-Jason
-Obi Wan Kenobi
