Old 03-21-2005, 06:28 PM
cargamer03
Angry power light flashing
hey guys and gals. having some tranny problems. it started today on the way to class. the shift from first to second is noticably harder but not too bad. i just noticed tonight that when the car is started the green power light in the dash flashes instead of staying lit. anyone with experience with this problem. am i screwed i am just starting to sell the car so hopefully not
THanks
Jon
Old 03-21-2005, 07:08 PM
Weasel 22
THanks
Jon
your SVX knows you are planning on selling it..so its initiated self-destruct mode....my power light flashes due to the TCU mod..me 'tinks' you have other troubles brewing..keep the SVX it will go away
Old 03-21-2005, 07:27 PM
lee lee is offline
The power light flashes to illuminate (sorry, can't help myself sometimes) a problem in the electronics on the previous run. Since you noticed harder shifting, then the power light flash, it probably means the dropping resistor has a) failed, or b) bad connection (loose, corroded, etc). Look at David's site to test what the power light code means. http://svx-iw.com/
Old 03-22-2005, 07:28 AM
n00b on demand's Avatar
Yea when i decided to keep my SVX all the problems went away on their own....weird huh....smart little cars
Old 03-22-2005, 11:20 AM
I'm willing to bet you get an error code 11.
Old 03-22-2005, 06:52 PM
cargamer03
what exactly is an error code 11
Old 03-23-2005, 08:12 AM
yeah as Weasel said, IT IS ALIVE.......... just say that you will not sell it anymore, and it will be the cheapest fix ever in SVX's history
Old 03-23-2005, 11:52 AM
Check on http://svx-iw.com/ in the codes section for a description of all the errors. 11 is normally caused by a bad resistor.
