Drive Train
I WAS LOOKING IN MY FUSE BOX AND NOTIVED THAT THE FUSE TO MAKE THE CAR TWO WHEEL DRIVE WAS IN.
WHEN I TOOK IT OUT THE CAR RIDE WAS VERY SHAKY ANY IDEAS? WHO FIXES A PROBLEM LIKE THIS? I WAS THINKING A RACE SHOP OR DRIVE SHAFT SHOP ? THANKS. SAM |
Check the how-to lockers for pulling trouble codes from the transmission. Let us know what code you get and we will go from there. It could be as simple as you have mismatched tires or it could be that you are in for a $3,000 bill.
If your power light blinks on startup then there's an electrical problem with the transmission.
The shakiness is due to the AWD binding up. Does it only shake around corners or all the time? It sounds like the front and rear tires are turning at different rates. Usually it's because of the tires but perhaps the previous owner installed a mismatched tranny/rear differential.
