Door Panel won't come off...
Taken out the 5 screws and already put some good sized cracks in things trying to pull up and pull it out as noted on the previous threads.(also, I have all the clips pulled free at the bottom)
It's wiggling around but it will NOT come off for nothing. Can anyone please further explain this process because the previous threads must be missing some step? Problem solved: There's 3 screws under the arm rest felt as opposed to just two like the how-tos would have you believe. Last edited by Mephis; 08-06-2009 at 01:29 AM. |
Re: Door Panel won't come off...
It acts like it's hung up some where between where the front screw in the armrest goes, and the door handle.
I'm still yanking around and trying to figure out what on earth is going on.... |
You did remove the screw under the handle right?
Yep... The goldish colored one.
It's moving freely-ish. It's just sort of rotating at the point I mentioned and refuses to break free. All along the edges is free, top and bottom is free, I have the lock down inside the door, and I can rotate it over the door handle but I can't get it to pull off. Anyone have any ideas? I'm having to do this over at a friend's house where I have some room and I'm just refreshing the page in hopes someone knows of something to try. Last edited by Mephis; 08-05-2009 at 05:40 PM. |
There are some plugs you have to disconnect for the locks and light.
There's 6 screws... Not 5.
I just pulled the arm rest support clean out of the metal frame of the door. You guys need to fix your write ups. |
Theres 5 securing the door panel to the door..... I think the 6th screw you're referring to is the one forward of the 2 big ones down in the armrest. It only secures the little plastic piece inside and is not necessary to remove to get the panel off.
