unknown prob.
i was not able to get car in shop today and i have no garage. so tomorrow is the day. my problem is i get a check engine light and my car seems to be less powerful as in maybe in safe mode. i need a oil change im 500 over do to a trip. i get a shakey feeling from the engine like a choke or a cough. i just had my exuast replaced and cats removed. the third o2 sensor is in a h pipe. when i got three days after exhuast is done my first ce light my car ran fine. i was thinking o2 sensor so i un hooked the battery and ce goes away. two more days later driving with cruise on i get another ce. i get a slight hiss from engine and notice a little bit of an antifreeze spatter. car is now running very poor. can a waterpump going out set ce lights? it could be a leak in the radator. im getting in the garage to determine and do an oil change tomorrow and check codes. any bets o2, oil, pump, or all the above. how does a car react before water pump lock up?
Get the codes first so there is no guessing. If you have no cats then the 3rd O2 sensor should be reporting an error.
after the oil change i found the problem i have a miss fire in cylender 4. the o2 sensor is fine which is good. there doesnt seem to be a head gasket prob. but maybe a plug wire. i changed plugs 2 1/2 months ago. everything has been perfect since 3 days ago. i might just take it to a shop which i know is a bad idea. any suggestions.
Todd
Down to none |
i know that what i ment
Plugs
What kind of plugs did you put in? I have had cheap plugs basically fall apart after a while, I'd pull the plugs and check everything you can do before dumping money into a shop.
Steve
It's not a car..it's a boat!! |
bosch plat 4s. its already in the shop. money is no issue but i rather spend it in other ways like the strip club. i kid no i have no garge and i live in ak its cold. also away from city. wife mil and we are 5 min from base but i am banned for 5 yrs. i some how managed my way there today to check the svx out and give it an oil change. and get codes checked.
