Capacitor
Anyone with experience know how I could figure out what kind of capacitor I need for my stereo system? Like how many farads or whatever?
yes, but more information is needed. For example, if the lights are dimming, is it because the stereo pulls to much peak amperage, but typically leaves enough left for the car, or does it always pull to much, leaving you stranded when the alt dies or battery isn't able to charge. How many watts? How many amps do the fuses add up to? How efficient is the amp/amps? What are the symptoms causing you to suspect a cap is required? Sometimes a cap does nothing but use the money you should have spent on an alternator, sometimes it helps. Are the main power and ground wires upgraded/maintained at least? What distances are between the amp and alternator? What gauge cable is it using? Is there a meter handy to measure actual draws on the line? It's a hobby of mine...as a general rule, I've seen 1-2 farads per 1000 watts output suggested. Again, that may be a complete waste of money in your situation, and lower end caps (some) can be shown to put a heavier load on the system while providing no benefit at all.
A capacitor close to the stereo system acts as a stored source of energy, which will fill in only very short term high load peaks, which drop the voltage at peak volume levels, as a result of line resistance and or inadequate supply capacity. There is no way of estimating your requirements, other than by cut and trial. You can take it that the the more capacity i.e. measured in farads the better.
i use 1f for my 1200 watt system and optima red top, works beautifully.
Hm thanks for the responses. My speakers only put out 560 watts and my sub does 300 but I eventually want to get another. Well those are the nominal outputs anyways. So I think I'm probably fine. The only reason I want one is because sometimes I'll have my car off but stereo on and I don't want it draining my battery.
A capacitor can in no way reduce the load on the battery.
Trevor nice STI badge!
