Old 12-10-2008, 11:45 AM
Driver power window
I have a problem with my window going all the way up. It stops about four inches from the top. The motor continues running and the glass kind of buckles and struggles. It goes down and up to this point normally. I removed the inside half of the door to get a better look and I could see a white pulley where the cable goes around but could not see where the hang up was. I have replaced the whole window regulator years ago on this same window. Could anyone direct me what to try or replace for this. Thanks in advance for any info.
Mike
95 Pearl Blue L
Old 12-10-2008, 04:36 PM
Old Fogey
Re: Driver power window
Results of search using "sleeve lock regulator"; a possible culprit perhaps?
http://www.subaru-svx.net/forum/sear...earchid=465028
Glenn
Old 12-11-2008, 05:13 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Your plastic sleeve lock regulator may be unseated...take your door panel off, peel back the plastic, and lower your window a bit to see if the cable is ok.
1995 Subaru Svx L / AWD
