Old 07-09-2008, 05:00 PM
surfer63 surfer63 is offline
head gasket replacement and parts questions
Hello,
I plan to replace my head gaskets to seal the blackhole where my coolant always ends up (I talk about it in this thread). I'm compiling a parts list and need some advice. I have 168K miles on the car. I replaced the trans less than 10K miles ago (along with the rear seal) so I don't want to lift out the engine. I plan to do the work with the motor in the car. This is my list so far:
Code:
Crankshaft seal	$6.53	1		806733030
Camshaft seal	$6.11	2		806732150
Camshaft plug	$2.65	2		807045030
O-ring for oil pump	$2.25	1		806919050
Water pump gasket	$1.94	1		21114AA051
Head gasket	$34.25	2		11044AA243
Valve cover gasket (right)	$12.92	1		13270AA031
Valve cover gasket (right)	$6.06	1		13294AA020
Valve cover gasket (right)	$6.06	1		13294AA030
Valve cover gasket (left)	$12.92	1		13272AA031
Valve cover gasket (left)	$6.06	1		13293AA011
Valve cover gasket (left)	$6.06	1		13293AA020
Oil separator cover gasket	$2.25	2		11832AA022
Crank pulley - I plan to get a cheapie from ebay (lightened but OEM size)... or possibly a 3 pulley set from Group-A performance. There's a question on whether to get a power steering pulley with coarse or fine splines, talked about here. Which does the SVX use?
Timing belt kit $200.00 1 (ebay, I doubt I'll get any arguments) except I can't find any kits that include the water pump, so...
Water pump... new or rebuilt? rock auto has one for like $50 or do you have a better place? (BTW, the thermostat is brand new, although I'll probably replace the gasket again)
Head washers - i don't want to pay $8 per bolt from subaru just to get new washers... home depot?
Spark plug gaskets... I couldn't find these in the parts catalog, I guess they attach under the valve cover, but do I need them and what's the part number?
timing cover seals... (13584-AA090 and 13586-AA060). do i need these? these haven't been mentioned very much on the forum.
OK, what am I forgetting? I welcome your infinite wisdom.
Old 07-09-2008, 06:15 PM
kwren's Avatar
kwren kwren is offline
Re: head gasket replacement and parts questions
Originally Posted by surfer63 View Post
Hello,
Definitely new for water pump. Would make no sense to put an old one on your car.
here is the information for timing belt - rollers- water pump.
I found it!
The Import Experts
405 E Arlington
Yakima, WA 98901
TEL : 1-800-572-3681
I called them for you and they have the kit with the water pump.
That is all I can do.
Take care,
Keith
