  #46
Old 06-27-2007, 10:19 AM
longassname's Avatar
Just some dude.
12psi is not 12psi nor 12psi nor 12psi. The mass of air pushed is what matters. Pressure is used and talked about because it's easy to measure; however, temperature has a huge effect on the mass of air that a given pressure in a given volume indicates.
12psi and below is the range where you don't really need intercooling or aftercooling. You can cool any forced induction air charge. The piece of hardware used with turbos is called and intercooler the piece of hardware used with superchargers is called an aftercooler. 6 of 1 half a dozen of the other.
If you have a system running 12psi of boost and you throw an intercooler or aftercooler on it your manifold pressures will drop. That 12 psi will be more like 8 psi. It's still pushing about the same amount of air; the air is just cooler now. So now you are making about the same power but your boost gauge shows 8 psi instead of 12.
As far as the comparisons between superchargers and turbos when not cooling the aircharge..it depends on the supercharger and turbo. A centrifugal supercharger is about the same as a turbo. A twin screw supercharger is much more efficient so the same amout of boost from a twin screw charger is more air than the same amount from a turbo or centrifugal. A roots blower is more efficient than most turbos below around 8 psi and less efficient above that. With turbos and centrifugals the efficiency varies widely depending on the matching of the turbo to the size of the engine as well. In practice it's pretty complicated.
Originally Posted by Nomad
I was reading and wondered : Is 12psi super charge same power of 12psi turbo ? But , only turbo offers intercooled option ?
Old 06-27-2007, 08:07 PM
SVX_Smoke_Out SVX_Smoke_Out is offline
Send a message via AIM to SVX_Smoke_Out
Been awhile since i poseted but i got a few questions. So whats the deal with the rear mounted turbos think they would work good on the SVX. Only thing im not sure about is the spool is it going to be laging because of the amount of tubing to be used for a rear mount setup?
Old 06-27-2007, 08:53 PM
sicksubie's Avatar
Been discussed....... not a good option
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 06-28-2007, 09:08 AM
Nomad Nomad is offline
The car named NIGHTMARE
Send a message via MSN to Nomad
ok , thanx , now im starting to understand !
Nightmare is the name of the car...
Old 07-18-2007, 11:54 AM
XT6Wagon XT6Wagon is offline
Mmm, missed the rear mount turbo question. Yes, rear mount turbos work. You are NOT going to get razor sharp response times, but you will get a good bit of extra power.
They work, and they will work well enough to blow the stock motor to pieces from too much boost/power. In someways they are safer than normal placed turbos since you typicly don't get the turbocharger "running away", or pressure spikes that can do **** like bend throttle plates. On the otherhand, lighting off a turbo such that its operating as a "jet engine" gets some stupid fast spool times and huge torque, so if you want to autoX, or break drivetrains, a close mount turbo is definitely the way to go.
However, its not that hard to use a more traditional subaru turbo position with most reasonable sized turbos, so might as well do that instead of re-inventing the wheel as it were.
Old 06-25-2008, 11:12 AM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
Re: Turbo options?
I just jacked a stock IHI RHB5 out of an 87 GL-10. If I rebuild it, could I use it?
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 06-25-2008, 06:28 PM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Re: Turbo options?
On your lawnmower perhaps.....
A bit too small for an SVX. Unless you run 4 of them.
Bob Légère
EG33 Impreza tweaks
Old 06-25-2008, 09:45 PM
Re: Turbo options?
LOL,
[SIGPIC][/SIGPIC]
Old 06-26-2008, 07:43 AM
Re: Turbo options?
LOL Eric said those exact words yesterday
Old 07-14-2008, 10:48 PM
Roo Roo is offline
Send a message via AIM to Roo Send a message via Yahoo to Roo
Re: Turbo options?
Hmm, that gives me an idea...
Individual IHI RHB5 turbos...one for each cylinder!!!
'92 SVX LS-L
Project Car for Open Road Racing
