Old 12-11-2006, 12:13 PM
SVX-elerate SVX-elerate is offline
SVX NEWB!!!
Turbo SVX... question(s)
Alright, my plan for my SVX is this- 5/6speed tranny swap, weight redux (significant weight redux!!!!), and a turbo setup of some sort (with supporting mods of course.) My question is this- is this engine stout enough to handle the loads of more fuel/air? I'm not planning on running 25psi or anything, something along the lines of 8-14psi respectively. I'm just concerned with the actual bottom end (if you will, lol. not sure boxer6's have a "bottom end") and whether or not it will hold up to the extra stress of forced induction. Any help would be appreciated. Thank you.
-Lucas
Old 12-11-2006, 12:20 PM
-Lucas
The EG33 has 7 main bearing and only 6 cylinders....the bottom end is plenty strong for the range of boost you're talking....but it does have hi compression pistons...so engine management and a IC is definitely needed...
Old 12-11-2006, 12:24 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
-Lucas
Lucas,
The road has been paved for your adventure. Everything you've stated has been done to date, just not all on one car I'd suggest using the "Search" feature of the site to bring yourself up-to-date. Phil has a running turbo set up, Mike/Old Tom/Young Tom are all running superchargers with between 8 and 12 psi of boost, LAN of ECUTune has the only software available for our ECU. Dave/Ben and Matt have taken just about every pound possible out of their SVXi - both cars still running NA. Young Tom is the current 5/6 spd go-to guy, while Old Tom is the 4.44 AT go-to guy.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-12-2006, 12:23 AM
SVX NEWB!!!
Ah, thank you. Sorry about not searching. I failed to notice that feature, lol.
Old 12-13-2006, 04:29 PM
Running more than 10psi is gonna be really tough... I roasted my motor running 12psi with my blower...
Old 12-13-2006, 06:12 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
I would tentativily place 10psi as the limit for stock internals on GOOD pump gas. What i mean by this limit...
Use your ears and your senses, but dont be suprised if it goes kaboom. I plan on running 9psi on pump gas( have previously ran 3.5ish and 9.5ish) and 11 psi on E85 at the track, fuel permitting(should not be a problem as i switch over to 2v7F)
phil
~Phil
