Old 12-08-2006, 10:04 AM
dwd1985 dwd1985 is offline
Possible exhaust leak, what are the consequences?
So last night as I left work around 11:00, I noticed that despite the fact that I had just driven my SVX a few hours earlier, it sounded way too loud all of a sudden. It sounded like it was much more powerful then it had been before (not a bad sound really, but wrong nonetheless) It also felt like I was in the wrong gear the whole way home, but I felt all 4 gears shifting, and then did it manually too, and it is not the transmission. Also, at idle, I can hear a kind of raspy exhaust noise, almost like from a motorcycle exhaust, and it is coming from directly under the drivers seat. I cant check it out thoroughly right now, because its about 30 degrees outside, and my garage is full of crap. Once I get everything cleared out from in there, I will jack it up, and visually inspect the undercarriage. Everything else is normal. So im pretty sure this is an exhaust leak. My questions are, 1: What are the ramifications of driving around with a leaky exhaust? Will it hurt anything else if I dont get it fixed right away? 2: How difficult and expensive is an exhaust leak to fix usually?
Old 12-08-2006, 11:29 AM
After getting it jacked up alittle bit, I have found that the sound is coming from where the front Y pipe meets underneath the car, directly under the center console, underneath the driver.
Old 12-08-2006, 11:39 AM
There's a lead donut there, I think you'll have to get it from Subaru though. You need to localize where it is leaking? Where the pipes "Y" into the the cat? Or where the cat connects to the mid-pipe?
There are different donuts used on either side of the cat. It's probably a good idea to get a new set of spring bolts for anything you're taking apart. Around here they are generally rusted solid and need to get cut off
Old 12-08-2006, 12:00 PM
The leak is where the pipes Y into the cat. I can see the gaskets under there, and they seem deteriorated, and when I touched them, some pieces flaked off. So I geuss this is probably my problem.
The diagram for the parts I will need is here:
http://www.subaruparts.com/diag/?mod...category=440-A
The gaskets look like part #8
The springs that you mentioned look like part #16
So I will need 2 donut gaskets, and it looks like 4 springs. How hard will this be to take apart and do myself? And are there any other parts I should get?
Old 12-08-2006, 12:01 PM
Yeah, right in front of the center cat is a common location for an exhaust leak. Unfortunately it's not the gaskets that are the problem but the flanges deteriorate and split open on the top side of the pipe.
Old 12-08-2006, 12:05 PM
#15 is the bolt that you may need to cut and #17 is the nut. Get underneath and check the condition, you may be able to re-use them all, or re-use the spring??
But if you need to get new, you will need 4 sets.
Old 12-08-2006, 12:25 PM
That's an area frequently prone to failure. The flanges and gaskets on my third cat rusted away, creating a leak where the Y-pipe meets the cat.
I originally had my exhaust shop cut out the area on both sides of the flanges where they connect and weld in two small pieces of pipe. I finally pulled the third cat and replaced it with a Magnaflow hi-flow cat, dual inlet/single outlet.
The converter for the 92 SVX (Magnaflow 94007) can be found here:
http://www.performancepeddler.com/SC...el=SVX&sCtrl=Y
44022PA021 Gasket: connecting Y-pipe to converter. About 20.00 each (need 2)
44022PA031 Gasket: connecting rear of converter to rest of exhaust. About $21.00
44059AA010 Bolt: connects converter to Y-pipe. (I believe you need 6) $3.00 each.
44028PA000 Spring: Used with above bolts. Another 6 at $8.50 each.
Cheaper to get another converter and have it welded in.
Old 12-08-2006, 12:29 PM
So are you saying that the donuts arent the problem, and there is something else I will need to order?
Old 12-08-2006, 12:33 PM
Yeah, basically what John said. The flanges don't last as long as the rest of that pipe.
Old 12-08-2006, 12:38 PM
Here is my shopping list right now. These are the prices after subaruparts.com's employee pricing thing:
Springs 44028PA000 (6 @ 5.94)= $35.64
Front gaskets 44022PA021 (2 @ $13.68)= $27.36
Rear Gasket 44022PA031= $14.48
Nuts 902350004 (6 @ $.47)= $2.82
Bolts 44059AA010 (6 @ $1.99)= $11.94
Total (with shipping)= $103.31
and I can do all of the work myself (hopefully, as long as I dont have to start cutting stuff)
I want to get this done and ordered, so if there are any other parts I may need, someone chime in and let me know.
Also, no one has mentioend yet if driving for a few days with the leaky exhaust will hurt anything. I cant imagine that it will, but I dont really know
Old 12-08-2006, 12:54 PM
I would check the condition of the flange before I bought the parts. If the flanges are gone, the new parts are useless.
An exhaust shop should be able to cut out the flange and weld in two small lengths of pipe, connecting the exhaust pipes directly to the converter, for less than the cost of the parts.
On the 92, you shouldn't have any problems. The O2 sensors are far enough in front of the leak that your CE light shouldn't come on. That could give you decreased gas mileage.
Old 12-08-2006, 03:52 PM
So it seems that whether or not the flanges are busted, I might as well just get the shop to weld in the pipes, that seems to be if not the cheapest, then still relatively cheap. Then I wont have to worry about gasket deterioration or anything like that anymore. Ill take it in tommorrow and have a shop do it. In the mean time, I sound like im driving around some riced out Honda civic. it sucks.
Old 12-11-2006, 12:11 PM
Well I took it down to the shop today, had them weld in 2 pieces of piping in front of the cat, and a flexible pipe on the back of it. Total cost was about $190. I figured it was worth it, instead of ordering $130 in parts, and then doing it myself, Id rather just pay the extra $60 and get it done, and not even worry about the gaskets in the future.
