Old 12-03-2005, 10:48 PM
black beast black beast is offline
Back Road Blazer
Send a message via AIM to black beast
Exclamation For the Love of God! Help me!!!
AHHHHHHH!
Sorry I had to get that out.
Ok heres the background, tell me if you know what is wrong: I was going down the highway at around 75mph when I heard a clunk, it was muffled, but I felt it, ten seconds later or so (under a minute) the speedo went from 75mph to 0mph, it was cool to watch, but frustrating. I thought, damn the tranny, so I speed up a little, and I speed up, tach. still worked. The check engine light is on, and I can hear something at the driving idle (1000rpm) it sounds like a remote controled car be pushed when off (the whine of the gears and such) but if I accelerate, it stops, and no its not covered by my exhaust, it is louder in the cab. When I get out, I can smell something not burning but unpleasent, and it is a strong odor.
Present: I am sitting here safe at home, but sad and confused.
What I want: Someone, anyone to tell me what the heck is wrong and about how much to fix it.
Thanks guys, I know that you will all try to help.
-Chris
'94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc.
Old 12-04-2005, 12:56 AM
Did you check to see if it's throwing a code?
Old 12-04-2005, 04:50 AM
thundering02's Avatar
Giong back to the beaters...
Sounds like you killed your speed sensor.... or someting along the lines.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 12-04-2005, 08:35 AM
Back Road Blazer
How much, for a speed sensor?
goodness, what a pain it the butt, I would love to think speed sensor, but will I get that same whining sound and the smell?
-Chris
Old 12-04-2005, 09:29 AM
n00b on demand's Avatar
Have you checked your front differential fluid? Whining sound sounds like diff problems.
Old 12-04-2005, 01:10 PM
You should first check all your car oil levels, engine, tranny, diff... then go underneath your car and try to pinpoint that smell. But most probably you have something wrong in your differential. the wining noise is from there...
Old 12-04-2005, 01:17 PM
could just be the speed sensor or it could be the linkage for it... I have a spare sensor here you could borrow to trouble shoot... You should check the front diff oil to make sure it is not toasted and also make sure there is enough in there... Drain it out and take note of the magnet on the plug... see what kind of shavings are on there..there should be some but nothing more than some dust...
BEFORE you do anything....just make sure it is plugged in first
Old 12-04-2005, 01:38 PM
Could it be something as simple as a speedometer cable that happened on my Legacy Turbo and I got a check engine light and a few other things didn't work also. it SVX has a cable doesn't it?
Old 12-04-2005, 06:25 PM
no...the svx is driven by a shaft in the front differential... That shaft leads to a sensor and that is where the ecu picks up the signal
