Old 12-30-2008, 11:35 AM
angrydan angrydan is offline
Any Tips For O2 Sensor Replacement?
I will be swapping out the O2 sensors in my SVX tomorrow and was wondering if there was anything special I might need to know before diving head first into this project? It seems like it should all be fairly straightforward to me, but I was curious if there might be any tricks...
Thanks!
Dan
Dan Taney
1996 Subaru SVX LSi (Red)
2019 Subaru WRX LTD
Old 12-30-2008, 11:46 AM
immortal_suby's Avatar
Thread Killah
Re: Any Tips For O2 Sensor Replacement?
Get an 02 sensor socket it makes the job much easier.
Soak in PB blaster for a long time before attempting to remove.
If they are really stubborn try turning them tight slightly to break off some crud and then loosen.
Locker Link
2015 BRZ Limited 6MT
Old 12-30-2008, 12:14 PM
Also heating them up with a torch if available would help a lot.
I got mine out with no real problems with vice grips. Not the best idea but it worked.
Old 12-30-2008, 03:32 PM
Don't worry about destroying the old ones. I was having trouble removing mine and then realized they're junk anyways, stop pussy footing around and get ruthless. I had them off in no time.
I used a 22mm closed end wrench with a notch cut in it to slip the wires through to reinstall the new ones.
Old 12-30-2008, 03:55 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
what Matt said + make sure to get some antiseize to use when installing the new sensor.
-Bill
p.s. you'll want to make sure to use a long handle ratchet with the O2 socket so you get plenty of leverage
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-30-2008, 05:24 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I soaked mine in wd40 overnight and they came out easy with an ordinary open ended spanner. When reinstalling, I found it easiest to connect it up first, then twist up the cable the wrong way - so that it untwists as you screw the sensor in.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 12-30-2008, 07:42 PM
Thanks, this all sounds very helpful! I am expecting the sensors to come in tomorrow, so we'll see how it goes!!
Thanks again!
-Dan
Old 12-30-2008, 08:01 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Which sensors did you get?
1995 POLO LSI 76K MILES SOLD
Old 12-30-2008, 08:11 PM
kwren's Avatar
kwren kwren is offline
forget the wd40 etc...
Simply unplug the wires at the quick disconnect and slide a long box end wrench over the wires and onto the 02 sensor and unscrew the thing!
Then install the new one, torque it correctly and then just push the 2 wire connectors together.
There you go!
Keith
Old 12-30-2008, 08:22 PM
I bought Bosch #13250's
Dan Taney
2019 Subaru WRX LTD
Old 12-30-2008, 10:17 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
You can find a write up on SVX-iw.com under 'exhaust'
Old 12-30-2008, 10:23 PM
Use a long pair of needlenose hemostats to reconnect the plugs up by the engine.
Be sure ti get the anti-seize compound on the threads and not on the actual sensor/tip.
