Old 06-26-2008, 06:10 PM
Davestone's Avatar
Davestone Davestone is offline
Newbie
Send a message via AIM to Davestone
new rotors
Now I'm sure this has been asked before, but I just got a new set of rotors off ebay. Should I get them turned before I put them on or are they ready to go?
Thanks,
David
David
'94 Laguna Blue L 110,000 5000k Hid's, K&N drop-in filter, leather seats(thanks to mysvxrocks), 350z rims, and now with big dent in rear passenger quarter panel
Purchased 12/2007 and lovin it
[SIGPIC][/SIGPIC]
Old 06-26-2008, 06:35 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: new rotors
They are ready to install but need to be de-greased with some brake kleen.
I found this site very helpful when I put my new brakes on.
http://www.stoptech.com/tech_info/te...e_papers.shtml
Old 06-27-2008, 04:31 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
Re: new rotors
im assuming you also have new pads?
if so i recommend breaking in the brakes before doing much driving
get going around 60+ mph and then hit your brakes hard (not hard enough for the ABS to kick in), until you reach about 40 mph
Do this multiple times, around 3-6
then drive around a bit to let the rotors cool off
BUT DO NOT STOP WITH YOUR BRAKES PRESSED
inch your way home using your emergency brake
this should ensure your brakes work well, esp. from that point on
just a little something i do
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 06-27-2008, 07:42 PM
Hondasucks's Avatar
Subaru Technician
Re: new rotors
The emergency brake shoes on an SVX are NOT INTENDED to stop the car except in an emergency, and they are very expensive dealer-only items. I few good hard stops, and a short (~5 minute) highway cruise should be sufficient to seat the pads in.
1986 VW Jetta
Old 06-27-2008, 07:50 PM
Re: new rotors
Turning rotors is a rare thing with modern cars. Factory rotors are made as thin as practical to save weight, so if they're turned, even though they are still above the min thickness spec, the weight loss will make the rotors become heat soaked MUCH faster, leading to nasty brake pulsation, etc.
Like Micheal said, some brake/parts cleaner and a quick wipe to get the storage grease off, and fire away.
