Old 10-14-2007, 08:50 PM
ridered777's Avatar
ridered777 ridered777 is offline
Finally HAS a 3rd pedal!!
Send a message via AIM to ridered777 Send a message via MSN to ridered777 Send a message via Yahoo to ridered777
Originally Posted by Crazy_pilot View Post
Hmm...The Eagle F1's come in 235/40/18, so I have both choices, but the 235/40 is about a half inch taller overall than a 255/35, so the rubbing might not be so much of an issue.
Maybe some 245/35's to be on the safe side? That's what I hope to go with, on these wheels. Though I'm looking into wrapping them with Pirelli's or Toyo's... Not sure yet.
I'm holding off till warm weather anyway, so I figure I got a good 5 months to decide.
-Craig
94 LSi 5spd Barcelona Red, 14Xk miles.
Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior.
(up next) Full cage, fuel cell, 327 swap
Old 10-15-2007, 04:27 AM
I still like the Murano's more. Anyone for their weight compared to RX-8s?
Old 10-15-2007, 04:48 AM
They look good but....
Murano wheels are off a jeep/fake-offroader. Unsprung weight is never an issue with these vehicle types. When they go for bigger or even standard alloys, weight of construction of the rim is considered an asset to defray possible off-road damage.
The car is not going to be raced, so a lightweight wheel is not a consideration in the design brief.
With no scales to back me up, I'm willing to bet the Murano wheel without tire is maybe 5 lbs heavier than the similarly un-attired RX8 wheel, which is off a sportscar.
Old 10-15-2007, 06:04 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
The Murano rims are noticeably heavier than stock. I would say roughly 5 pounds is about right. I will put it on a digital scale once I change my my rims back to stock for the winter.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-15-2007, 06:26 AM
I thought so.... well you cannot always get everything in life
Old 10-15-2007, 06:40 AM
And he who laughs last often has a slow sense of humour.
Old 10-15-2007, 06:42 AM
Do you notice the weight in the handling Tim? Are the brakes slower to haul the weight down, for instance, if the shocks are getting it hard to keep the rubber on the tarmac?
Old 10-17-2007, 04:05 PM
UPnorth362's Avatar
UPnorth362 UPnorth362 is offline
Send a message via Yahoo to UPnorth362
Just wanted to bump this up for SVX Maxximus. Also wanted to note that 235-35-18 is probably closer to stock tire height than the 235-40-that I used. I have a 4.44 trans, and went with a little taller tire to bring the cruising RPMs down. Also, it was the only size relative to the stock size that Falken made with reinforced side walls.
IT'S 5:00 SOMEWHERE!!!
92 Liquid Silver SVX LS-L
Old 10-17-2007, 05:35 PM
Tim's Avatar
Tim Tim is offline
I noticed a little bit of change but I think it was really only in acceleration. It's not noticeable enough to push me towards another set of rims, but if I were taking the car to the drag strip I would definitely go back to the stock rims.
The ride was stiffer, and it seems more energy from the bumps were sent to the cabin. I already had bad bump steer do to my failing rear struts, but it didn't much any worse with the larger rims.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-17-2007, 06:28 PM
That's interesting. Thanks.
You are probably correct about the acceleration. A bigger or heavier wheel has more mass. It will take more rotational energy to turn it.
Therefore your drivetrain with the heavier wheels will absorb more of your engine torque output, a bigger percentage than with the lighter wheels. Result; it will accelerate more slowly.
