Question about Sea Foam Cleaning ASAP!
I was told to use Sea Foam to clean out my engine, but I dont exactly know what to pour it in. A memeber said to pour about a third of it into the big vacuum line on the back of the intake duct, but there seems to be alot of vacuum lines. Also, he said to pour a third into the vacuum line thats hooked to the end of the driver sides of the intake duct, and again Im not sure which one this is. I am new to working on cars so i dont want to pour it into the wrong line. Any help? Pictures please.
P.S. respond as quickly ASAP because I have my hood popped in my driveway as we speak Thanks |
PM sent
the key with a vaccuum line...is they "suck" air to the vaccuum source. which just happens to be your intake manifold. So any line coming out of the intake manifold, will infact work. Be sure to change your oil after you do this. I'd change the spark plugs as well, but thats not as neccesary.
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
I wouldn't run it through the vacuum lines. The Intake has a special coating on it that can be eaten away by SeaFoam. Would be better to pour it in through the PCV valve.
... Tech?
where did this special coating come from, and how was it determined that seafoam "eats away" at it... unless its carbon based that seems like some misinformation... however I may just not be informed.
