AAH! Help! OBD-II 5 speed swap wont start!!!
OK here is the deal. I bought and swapped in a 5 speed transmission from a 1997 impreza L. Every thing has gone great so far...... except now that I am 99 percent done and it is time for me to start her up, nothing... I've fallowed huck369's write up and have been communicating with him through out this project. I can't get it to start up after putting the transmission in. Now I have come to a realization about this car. I have the 1996 Lsi that has the OBD-II management system and hucks is a OBD-I from what I remember... I checked battery and it seems alright and starts other vehicles. There are three small clicks after the pump turns on for a second and then nothing. My air bag light is always on and nothing else. I got all the dash lights to turn on a few times like they are suppose to when the key is in the on position and not running. I'm not sure if this matters or not though. Is there any one who might know if I have to do some other wiring instead because I am OBD-II. If not is there any one else who knows what I have to wire up etc that can send me some pics or write up of what to rewire etc. Some one help I just want to drive my baby... lol. Any suggestions would be great. If any one needs any more info let me know. PLLLEEEAAASSSEE SOME ONE HELP ME FIGURE THIS OUT...!
Brandon774 Also if any one is interested in the swap picture you can visit my myspace page here. Thanks every one. http://viewmorepics.myspace.com/inde...1836535&page=1 Last edited by Brandon770; 04-10-2009 at 05:23 AM. |
Re: AAH! Help! OBD-II 5 speed swap wont start!!!
Did you wire in the clutch position switch to fool it into thinking it's in "Neutral" when you are trying to start it?
Or do you still have the Neutral Safety Switch hooked up? If you still have the NSS hooked up, make sure it is set to "Nuetral"
I tried jumping the black/Yellow and Blue/yellow wires as well as the NSS in all positions. Although I was not sure as to which wires on the four prong plug to jump so I tried every combo on that as well. I even took the wires off the auto shifter and tried every combo with those. I even tried making sure any parts that were previously touching metal were as well. I'm at wits end here man lol. I will be trying to manually jump it from the starter later to see if it is something else... Damn.. If I have to I'll put a push button on the damn thing and call it good..
Black w/Yellow tracer and the Blue w/White wires.....
They should be right next to each other in a corner of the connector... (This is assuming the OBDII has the same wire colors)
Problem solved. Thanks again lol... For about the 100th time. Was a grounding problem. Just waiting for the drive shaft.
congratulations on the resolution.
as i started another thread on 96~97 OBDII manual conversion issue tracking, are you having any issue with the CEL light on for the transmission control unit not able to send signal after the conversion? thanks for the sharing.. |
