How much unequal tire wear between wheels
Hi All,
Daughter hit a curb, took out sidewall on 92. Sears provided brand new Falken 512 tire. BUT, tires had 6k on them, old tire had 1/16" wear (.062") compared to new. Will this burn out tranny/diff? TIA, Gordon
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
Allowable tire wear
From what I have read, Subaru says that all tires must be within 1/4 inch of each other. With only 1/16 of wear I think it is likely OK. You need to physically measure the outside circumfrence though to see the difference. Measure with the vehicle jacked up or wheel removed, also check the tire pressure, as this will vary the measurement.
Ken |
I would say that there would be problems with up to 1/4" wear. I would also measure from the ground to the top of the wheel and make all tires the same. There has been quite a few threads discussing this topic and that is one of the ways to make the rolling diameter the same.
the standard rule at most tire shops is 2/32-4/32 your fine
Easy way to measure: Mark each tire sidewall directly above the ground (6:00) and roll the car forward until one mark is back at 6:00. Then check the position of the remaining tires.
Give your most difficult job to the laziest person and he'll find the easiest way to do it.
With the new tire, i would put in the back, the cars are dominantly fwd when awd is not engaged.
Beav, thats a great idea!
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
