Outside Mirror Glass Replacement Procedure
Author: Subaru NUMBER: 12-65-96 DATE: 06-11-96 APPLICABILITY: LOYALE, XT, LEGACY (INCLUDING SPECIAL EDITIONS, RIGHT-HAND DRIVES), and SVX SUBJECT: OUTSIDE MIRROR CLASS REPLACEMENT PROCEDURE Tools required: small regular screwdriver, heat gun, safety glasses, gloves, scraper or equivalent. If you encounter a customer complaint of a cracked or distorted outside mirror glass (LH or RH), the following steps should be followed after confirming proper operation of the mirror assembly (warranty coverage for cracks and distortions from product failure only - NOT from stone chips, abuse, etc.). Part numbers for the replacement mirrors can be obtained through normal parts channels. In some cases, a heated mirror replacement will be used in a non-heated mirror assembly. This is a normal part number supersession. Note: Wear Safety Classes & Gloves Removal of damaged mirror
Installation of mirror glass
This new operation number can be claimed using the following warranty information for vehicles within the terms of the Subaru Limited Warranty, since it is not necessary to remove the mirror assembly from the vehicle. . |
