? remove panel below steering wheel ?
the one above knees that holds the switches?
searched: remove panel below wheel , 29 results not helpful preparing to install remote start........
"Some work occaisionally is fine, but I bought the car for the road, not for the garage. " BoxerFanatic click here for fuelly mpg info |
Re: ? remove panel below steering wheel ?
I just pulled it from the lower part and voila!
95´ Subaru SVX EURO 85' Mercedes 190 2.3-16 86' Mercedes 190E 70' Olds Toronado 98' Renault Chamade 82' Honda Prelude 79' Honda Accord awaiting restomod. 69' Mustang Hardtop 67' Jeep Ford Willys awaiting restoration. 67' IKA Torino Coupe 74' Renault Torino Coupe |
yes, remove
it seems to hang up in the middle lower edges are free
Remove the coin holder, power mirror, and parking light switches. Look in where the switches are and you'll see a couple screws. Remove them and also look for plastic molded tabs that have metal clips on the end of them. Be careful removing the cover so you don't crack the plastic.
On the left side near the vent will be a small metal clip that you slightly have to lift upwards as you remove the panel. Remember to disconnect the light by the brake pedal and the winter wipers switch. |
Harvey.,
Any trick to the port that's where the coin holder is on obd2 models?
Subiemech: I am putting a remote start in too, I may be able to help if you have any questions about wires.
__________________ -Dan 1996 Polo Green SVX L - 85k 1992 Ebony SVX LS-L - 193k (parts) |
any thoughts? haha i will just rip it out, hopefully nothing gets damaged.
use pick to pull tabs towards center ??
