Rattle in Cat?
I getting vibrating/rattle that sounds like it is comming from the cat. I only rattles at around 1800-2000 rpms then goes away. so I hear every time it shifts. It seems it only does it after it warms up after 5 min. or so. Anybody had this problem?:(
Everybody has or will have this problem. Sometimes its the heat shields. They can be removed or repacked with fireproof insulation. Other times its the cat or resinator breaking apart. |
Had the same embarrasing vibration/rattle when I bought the 94 ...
Elite Stainless Exhaust muffler shop cut out the resonator and welded a straight pipe in All for $30
92 SVX LS Pearl 94 SVX LSi Barcelona Red 82 Brat 4WD Bob |
rattle = subsrtait or heat shield
I removed the heat shields and repacked them with strips of heat wrap, the the type racers (and some ricers ) put around their headers - problem solved. Model rocket wadding, found at a hobby store should also be effective if you want a cheaper option
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
It's driving me crazy too
I have exactly the same heat shield rattle. I was going to take the car to the dealer to have it fixed (the local dealer claims they have a couple of techs who worked on SVXs since they were new), but maybe I'll just take it to my local muffler shop. (One mile drive vs. 25 mile drive to the dealer.) Mine comes in at about 1500 rpm, and gets less as the car warms up. It never goes away completely, however. There's always something...
The great white fleet: '91 Alfa Romeo 164L 5-speed '92 Subaru SVX LSL '93 Mercury (Aussie) Capri |
This rattle could be the heat shield, but maybe not. If the fix above does not make the rattle go away, then the cause is very likely to be loose baffles in the resonator. That's what it was in mine. I did the straight pipe insert fix, and did not like the sound afterwards, it was coarse. A new resonator is expensive. If it's the resonator, cut it out and cut it open. Tack weld or solder the loose plates. Stitch it all up again and weld it back in place. No more rattles. [Mine use to rattle, fizz and buzz at around 1700 rpm, I think] Joe
Thanks for all your ideas on what the problem is. It appears to be a common problem with these cars. I will climb under there and see what the problem is. Is there anyway to tell where it is comming from when I get under there?
ps. "Yourconfused" said "rattle = subsrtait or heat shield" What is "substrait"? |
If you climb under, you may find that a heat shield is loose. Heat shields will be above the exhaust components. They are fitted in an attempt to stop unwanted heat leaking into the cabin. If one or more is loose, what can happen is they will vibrate in unison with the exhaust, as the exhaust is bolted straight onto the engine, and vibrates when the engine does. [In scientific terms, this is called sympathetic vibration ] This is the first job you must do, ensure nothing is loose and able to rattle. If it still makes a noise after you have secured all the heat shields, then it is very likely you have loose internal baffles in the resonator. Proceed to fix as outlined above. Joe
Go to a shop that does Stainless and have them weld a Stainless pipe in there. The guy at the shop told me the SVX exhaust is Stainless. Try that first. It's the easy fix.
If you cut out the resonator, and the rattle is actually heat shields, it will still rattle with the stainless pipe. And the resonator was put in there in the first place to control the gas velocity and give higher torque in conjunction with the engine scavenging system. If you take it away for no good reason, the car will still work OK, but not as the engineers designed it. And it will sound awful. My 2c. Joe
