Radiator OEM top foam
Hi Guys (and Gals!!)
My OEM radiator top foam has now got split and bits missing. Does anyone know if it is still available - if so what P/N is?. if not then I will but something - but what glue should I use to mount it to metal part of radiator?. thanks
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: Radiator OEM top foam
I just used some home weather stripping foam of the right size. It's peel and stick.
+1
Thats what I did
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
Found some really good "sticky" stuff - so no need to glue/tape into place.
Just had to buy 2 meters of the stuff (only actually required 700mm). I have been running around with this for a few days now & not an issue. I undid the top mounts (metal with rubber insets) as seen in the first photo, then held radiator back (by using small piece of wood) - so it was approx 5mm from normal position. Then slid in the foam, released the wood and then returned the mounts. Job only took 5 minutes.
Your car looks like it's new. It must be nice to live in such a pleasant climate.
Thanks it is just coming up to 157,000kms
That looks good.
For those of us in the US. This is what I got from Amazon. Its less than $3 dollars and worked well for me. I also undid the upper mounts to get a better fit. http://www.amazon.com/gp/product/B00...rch_detailpage
