replacement rear speakers
I just want to replace the rear speakers because one is damaged. Is there any negative to replacing a woofer with a co-ax? It seems like there are more choices of pure woofers when the size is 6 1/2 instead of 6x9. Do 6 1/2's fit without any cutting?
What about nominal 4 ohm vs 8 ohm? Thanks, Ken |
Re: replacement rear speakers
I recommend you keep the 6x9's. Look at some Infinity Kappa's. Very nice speaker, not too much cash. They come with a crossover so you will have to keep the 14g(?) wire that runs to them.
If you do want to go with 6 1/2's I believe you should be able to find some adapter's or you could just fab your own pretty easily with some MDF. And lastly, you can run a 4ohm speaker off of an 8ohm output signal, but not the other way around. It is best practice to match them, though.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
Sticking with 6x9's is fine with me. I just don't know if existing overall balance will be enhanced or degraded with the addition of a tweeter back there.
So will the co-ax go as deep or deeper than the stock woofers? I assume so as replacements are probably of a higher quality than stock. |
The tweeter can be disconnected if you like, it is simple to remove the connectors from the back of the speaker (I actually soldered mine because one was falling off). I really enjoy the way mine sound, and am adding 6 1/2 Infinity Kappa Perfects (with the dash tweeters) because now my front speakers don't sound good to me at all. I have them powered with a 100x4 Eclipse Amp.
I am not sure what you mean by "will the co-ax be deeper?"
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted Last edited by Cam; 09-08-2010 at 06:13 PM. |
By "co-ax deeper" I meant that will the low end frequency response by lower for the stock woofer or a co-ax.
I have Sony Xplod 6x9 3-ways in back and they sound great. I have always been a fan of the sound quality of 3-way speakers all around. |
So if you put 3 way's in the back, what did you do to bypass the factory crossover?
or maybe I should also ask where is the factory crossover? or did you use your own wiring from the head unit to the back? |
There is none for the back, the stock speakers were full-range. The only crossover was for the tweeters from what I understand. My rears have crisp highs so im sure there is no low-pass crossover.
full range and not woofers?? well that explains everything!
Kappa's sound like the way to go then. Ken |
Thanks for the correction So-Cal. I indeed had it backwards. My 6x9's sound excellent across the entire frequency range but are a bit low-mid heavy. I put the infinity crossover in and ran good quality (monster) rca's from my source unit. They sound great. My amp also has a crossover on it that I use to control frequencies a little more. Then again I am anal retention with my audio stuff.
Um, now that you said mid heaviness, I will peruse Boston Acoustics, MB Quart and Alpine instead.
