Vapor from engine . . . . .
Recently I've been getting an odor and visible vapor upon startup sometimes. When I pop the hood I see vapor rising up and backward from under the throttle body area (or intake tube) at the rear of the engine. Goes away after a minute or two (abruptly).
Any ideas? THANKS FOR YOUR THOUGHTS!
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! |
Is the same stuff coming out of your tailpipes? Mine does this too right now due to the fact that I have an exhaust leak just before the third cat, in my case its just water vapor in the exhaust. After a minute or two the vapor stops coming from the leak point and only comes out of the tailpipes, not sure exactly why. A simple test to see what the vapor is is to watch it as it drifts off, if it dissipates within a fairly short distance, its water vapor which is normal on a cold day, otherwise its smoke. You mentioned an odor, what does it smell like?
My two loves: SVX: 1992 Black LS-L, SS Brake Lines, Slotted/Drilled Front Rotors, Level10 Stage 3 Trans, 4.44s, Phantom Grip LSD PC: AMD Phenom 9950BE@3.0GHz, 4GB G.Skill DDR2, Asus M3A78-T, Radeon HD3850 512MB x2 |
Re: Vapor from engine . . . . .
