Old 04-25-2021, 01:50 PM
Black88GTA's Avatar
Black88GTA Black88GTA is offline
look like a leprechaun to me
Brake caliper rebuild - information dump, aka things I wish I knew beforehand
So in my quest to get my '92 back on the road, I found that the brakes were all shot from sitting around for 10 years. Decided to replace everything - calipers, rotors pads. The rear calipers were just balls of rust, so I decided to get new coated ones from Rock Auto rather than mess with them. The front calipers were stuck from sitting, but otherwise in nice shape - turned out they were plated for rust prevention, and then painted. All of the replacement front calipers I could find on Rock Auto were untreated, so either I'd have to paint them, or end up with rusty calipers again after a couple weeks. So, I decided to rebuild the front calipers instead of replacing.
Turns out, you can get a basic rebuild kit (piston seals / boots) and new pistons off the shelf with minimal hassle and cost, but NOBODY sells a kit for the 3 little rubber boots that go over the sliding sleeve and the lock pin. Except Subaru, who wants to charge $45 IIRC for a single caliper rebuild kit. Thanks guys .
So I started pulling up listings for similar cars on Rock Auto trying to match up the boots I had with pictures, which was kind of a crapshoot. Then I got the idea to email Carlson (who makes most of the brake kits they sell on RA) and Dorman to see if they could cross-reference the boot numbers and tell me which kits had those pieces in it. Dorman wasn't able to do it, but Carlson came through in a big way. Turns out, they were able to do exactly what I asked and gave me part numbers for cheap, readily available kits that include the parts I needed. I was able to find all 3 (although in 3 separate kits ) but each kit at least included two of the boots, so you can do both front calipers with one of each kit. And have a bunch of weird ones left over to add to the misc parts stash. I suggested that they pack these 3 into a kit for the SVX (since they're making them anyway) and they could be the only ones who sell a kit for our cars, but I have a feeling that won't go anywhere.
Anyway, I figured I'd save someone else the detective work on the boots and post the results here for reference, along with other misc information
Subaru P/N for a rebuild kit (includes all 3 pin boots, piston seals, piston boots, and a bit of grease): 26297PA010 Easy mode, but most expensive option.
Boot # 20894 (rear side of caliper, fits over sliding sleeve, flange goes INSIDE caliper) : Carlson 16061, 2 included per kit
Boot # 21089 (front side of caliper, fits over sliding sleeve, flange goes OUTSIDE caliper) : Carlson 16065, 2 included per kit
Boot # 22076 (fits between pivot on caliper bracket and caliper body) : Carlson 16081 OR 16198, 2 included per kit
For reference, the pistons / rebuild kits I used for the rest are as follows:
Caliper piston: Centric 146.43006
Piston boot / seal kit: Carlson 15156
In the event you want to use taps / dies to clean up the threads on the front hardware or calipers, be aware that both the lock pin and the mounting bolts are oddball thread pitches that typically aren't included in the standard tap / die sets. I had to get the tools separately. Not sure about rears, as I didn't take these apart. the thread information (at least for my front calipers) is as follows:
Caliper to knuckle bolts (front): M12x1.25
Caliper lock pin (front): M10x1.0
Bonus round: Torque specs!
FRONT:
Caliper bracket to knuckle bolts: 51 - 65 ft-lb
Caliper lock pin: 25 - 30 ft-lb
Hose attachment banjo bolt: 11 - 15 ft-lb
Bleed screw: 5.1 - 6.5 ft-lb
REAR:
Caliper bracket to knuckle bolts: 34 - 43 ft-lb
Caliper lock pin: 16 - 23 ft-lb
Hose attachment banjo bolt: 12 - 14 ft-lb
Hope this helps someone out, it took me a bit to track all this down. Wanted to dump it in one place to hopefully save someone else the hassle.
Ebony/Gray '92 LS-L, @123k - bought 01/17/2010, parked for 10 years. Getting back on the road.
Old 04-25-2021, 03:11 PM
Re: Brake caliper rebuild - information dump, aka things I wish I knew beforehand
Good information.
Old 04-26-2021, 08:00 AM
SVX_MY_BABY's Avatar
Great info.
I accidentally tore one of the boots on one of my front callipers a few years back. After running around the local parts shops I gave up trying to get a replacement and just grease that calliper frequently.
This info will save me the hassle.
Peter
Old 04-26-2022, 05:59 PM
**Ewie**'s Avatar
**Ewie** **Ewie** is offline
Aussie in enemy territory
This is great!! Thanks!! I'm about to rebuild my callipers to get rid of the rattles. Planning on shooting a video as well since I plan on having the callipers vapor blasted, the rotors machined new hoses etc etc.. should look mint once done.
Old 04-27-2022, 08:07 PM
SvXit's Avatar
SvXit SvXit is offline
Member Incognito
Thank you for posting this!! Just wanted to correct one thing, re: Subaru, which I did not find out until I asked our amazing parts lady at Subaru of Annapolis: the caliper rebuild kits come with parts for both front or both rear calipers, not just one. I thought it was just the one until she corrected me on it, and now that I have them they that is the case. The only thing I found was odd is that there are metal circular clips for the rear calipers but not for the fronts.
I had my old set of calipers cleaned up and powder coated in gold, but now have to put it all together, which I'm dreading, but will tackle at some point in the near future. The '97 I recently bough has torn boots front to rear, sooo....
SvXit
"Flossie" - 92 black over pearl LS-L (sold)
"Gorgeous George" - 98 Audi A8 (traded)
"Gorgeous Genny" - 02 Audi S8 (sold)
"Green Giant" - 00 Land Rover Disco II
"Grey Wülf" - 05 Volvo S60 R
"Silver Surfer" - 92 black over liquid silver LS-L
"9 of 7" - 97 bordeaux pearl, formerly with Earl Steele
