My built VG30DETT 300ZX engine is completed!
I know this a little bit off topic, but I figured someone would like to see it. It is my VG30DETT out of my '90 300ZX Twin Turbo. Just had it built at Import Parts Pro and should easily sustain 1,000 HP. It has :
Weisco Pistons with full ceramic/moly coatings Eagle Rods ARP Rod Studs ARP Main Studs Block Inspected and acid dipped Block redecked Block water passage bored out for more water to back cylinders Block Bored and Honed using a Torque Plate Crank knife edged Crank center weight tig welded into place Crank balanced New Moly Coated Race Spec Main bearings installed New Moly Coated Race Spec Rod bearings installed Block prepped and assembled ARP Head Studs Tomei Cams(270 duration / 10.25mm lift) Tomei HD Valve Springs Tomei Solid Lifters Titanium Retainers Ferrea 1mm Oversized Valves Heads inspected and cleaned Heads Pressure Tested Heads redecked Ported exhaust and intake runners 5 angle radius cut valve job Combustion Chamber work Valve heights set New OEM Valve stem seals Heads prepped and assembled New OEM Cam Seals New Cometic Metal Head Gaskets Total: $10,000 Continued.....
______________________________________________ 1990 Nissan 300ZX TT |
Re: My built VG30DETT 300ZX engine is completed!
Continued....
Once this thing in broken in, I will be pushing around 700WHP. I can't wait!
Very nice! Should be a street monster.
$10K eh?? You must be a retired Wall Street CEO!! Glenn
Beautiful!!! Congrats!!
Someone bent your block!
Its in some weird "V" type shape! Just kidding. I know some people have this weird fascination with "non-boxer" motors for some reason. Good luck with it and I hope you put down the numbers you're looking for! Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few and acouple more 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold Mods: 4.11, rust 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
Haha. I actually love boxer engines. I used to race Subarus back in the day.
