Atco Dragstrip
MikeCG, TomsSVX and I were at Atco this morning for a Test and Tune, my very first drag strip drive. We were joined by Mike621 and Its Just Eric, there to spectate
Will let Tom and Mike tell you about their drives. Tom had a bit of misfortune. My first two slips (I'm car 111): Then, I asked Tom to drive my car to show me how it should be done. He said he wouldn't try to get everything out of it, that he would baby the clutch a little bit at the start. But, he still managed to best my time by 0.3 sec. He said he thought there were still a few more tenths to be taken out of the time with a more aggressive rev's and clutch drop at the start.Results were 0.3 better than my best. When you want it done right, go to an expert.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
thanks for the compliments Dan, I don't really have much to say about today but... **** happens. It was good to see everyone today and have a good time back at the track... It has been close to a year since I last went. I will be back again sometime but it doesn't look like anytime soon. I am going to follow my modo and with every repair make it a modification... Built EG33 comming this year
Tom |
so what did you break now tom?
piston rings or there is just a nice big hole in one of them
Tom |
Nice pics! Great times Dan (and Tom driving your car).
Sorry to hear about your engine Tom. Good luck rebuilding her stringer and better! -Chike
Tom ive got a couple engines in the garage with just over 100k. Let me know if you need anything.
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon |
oh BTW i believe Mike621 has some video and I know he has video of my final run in which there is a lot of smoke
Tom |
-Bill
