Old 05-07-2018, 04:47 PM
Huskymaniac's Avatar
Uses the ignore feature
Headlight vent tubes
Any good suggestions on how to clean them out without blowing crap into the headlights or sucking in whatever is in there, likely spider nests.
Tony
Old 05-07-2018, 06:10 PM
Re: Headlight vent tubes
Any sort of turkey baster type thing could be rigged up. A small vacuum pump too.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 05-07-2018, 10:15 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
take out the bulbs before you start - I used a small fish tank pump to suck the gunk out of mine.....
