Old 04-03-2008, 08:16 PM
Nforcer Nforcer is offline
You have been Nforced!
Flooding out???
Here is the problem description: My car feels like it's stumbling all over itself if I give it more than 1/4 throttle. When this starts up, I can come completely off of the throttle and gently get back on it and sometimes it goes away. I've replaced the oxygen sensors (both banks), cleaned the MAF, changed the CTS, and given it new plugs. Bosh platinum +4's, and a new K&N air filter. Oh yeah, replaced the fuel filter. Anything else that I've missed???? Does anybody have a spare set of coils laying around ??
Old 04-04-2008, 08:01 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
No trouble codes?
Gene
Gene and Ben
Old 04-04-2008, 08:20 AM
You know, I had issues with the bosch plugs on cold start-ups. They don't work well until the engine is hot. This is also because the EG33 should be using NGK iridiums. But this probably isn't the cause of your issue. Does it do this all the time or only when the engine is cold??
Old 04-04-2008, 10:04 AM
This happens all the time. No engine codes. well, except for the torque code. but what can you do? lol 5mt. I bought a new set of regular ngk's this morning and put them in. It's still stumbling all over itself.
Old 04-04-2008, 10:23 AM
torque code??? You did the jumper in the 5mt writeup didn't you??? If you did, undo it and all should be better
tom
Old 04-04-2008, 10:30 AM
I'll go outside and undo that jumper now. but i'm still killing myself trying to find out why i'm stumbling all over myself. this just started a few weeks back, and has gotten progressively worse. do you mind pm'ing me with your number so I can pick at your head? I just checked. I had 4 codes stored in the ecu. 23 / 33 / 37 / 38 so I just cleared out the computer. I'll drive it around for a little bit today and recheck.
