engine knock
does anyone else's engine knock when it's started up cold? my dealer told me they all do it with age because of the liners in the cylinders. it does go away as soon as it warms up but it definitely sounds like the crank area that it comes from.how hard is it to replace the bearings if thats the cause? is the dealer feeding me bs and i'm about to blow up my car? Jason
My car knocks but not in revers, 1,2,or 3 i duno these damn cars are confusing and do alot of weird **** haha i still cant figure out how to get mine started!!!!
mine knocks no matter what when it's cold. you can hear it pretty godd sometimes and it gets scary. but when it's warm it's as quiet as can be. i noticed it got louder when i switched to castrol gtx start up. like i said in a previous post somewhere on here. castrol SUCKS! have already lost a small block because of it, not trying to lose my little boxer too.willALWAYS use maxlife from now on. best thing i've found. so what's the problem with yours? why did it stop running? feed me some info. maybe i can help alittle. you never know. nevermind just found your thread. thinking.......... Last edited by Budfreak; 05-24-2005 at 10:36 PM. |
Its probably the hydraulic lifters. Its common to many SVXes. Doesn't seem to cause a problem.
A slight knocking or ticking sound is VERY common on all Subaru's after a cold start. As long as it goes away when the engine is warm you'll be fine. Not that long ago Subaru sent out a memo basically saying "a slight ticking sound that gradually goes away as the engine warms and is barely noticeable from inside the car is normal..."....or something along those lines.
As previously mentioned you may also have a hydraulic lifter that is misbehaving when cold. Either way I'm sure your engine is fine. Dave |
Yea when i start my car in the morning after its been sitting for a while there is a knocking noise and ticking as well. It goes away as the car warms up.
