Old 09-09-2007, 02:33 PM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
Bubbling Noise???
This may be coming from a sort of Vapor Lock, but I have noticed a somewhat Bubbling Noise in the right rear area from time to time.
It's not loud enough to show during driving, and it seems to be only on first startup of the day.
Any input on what to check would be appreciated.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 09-09-2007, 02:35 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
hey weird I've had this noise a few times too, only after driving for a while and turning the car off at home
Brian
Old 09-10-2007, 06:14 AM
dcarrb dcarrb is offline
Fuel gurgling in the tank. Normal life sounds, if my cars are any indication.
dcb
Old 09-10-2007, 03:25 PM
crazyhorse's Avatar
242,000 mi on oem trans
Doesn't the fuel tank have a transfer pump? If so, I'd put even $$$ on that being your noise.
"42"
Current Stable By Age:
Old 09-10-2007, 10:28 PM
budbaer's Avatar
budbaer budbaer is offline
Send a message via AIM to budbaer Send a message via Yahoo to budbaer
Mine makes the same noise. I always assumed it was the fuel tank depressurizing after the fuel pump turns off.
Old 09-11-2007, 12:11 AM
Thanks all..
The noise is during startup, and there is a noise on shutdown, but that one comes from the Driver's side, and I assume that is a pump.
I'll pay more attention to conditions in the next few days, since it's due to warm up again here.
Edit.... It just sounds different from the outside. If you listen to the right rear quarter, you can hear it very clearly.
It sounds more like a mechanical sound from the inside. I thought maybe I had the right rear diff letting go.
Thanks again.
The Worm
_______________
No Mods, 33K Miles
Last edited by ShiuludeSVX; 09-11-2007 at 05:23 PM. Reason: don't need another post for this one.
Old 09-12-2007, 07:00 PM
thumper_svx's Avatar
thumper_svx thumper_svx is offline
Either committed, or should be
Send a message via ICQ to thumper_svx Send a message via Yahoo to thumper_svx
Not specifically an answer for the poster, but an answer to others.
As a three-time SVX owner (offender?) I will say that noises on startup and shutdown seem to be the norm. It's a Subaru thing... every Subaru I owned (including a Loyale and a Legacy) demonstrated this problem. There's a bubbling noise after the engine shuts down... well, I traced this in my SVX to the cooling and air conditioning systems. They both do it, and cause slightly different noises. A slight hissing/bubbling noise is the A/C. A deeper bubbling noise is the cooling system.
Now, a bubbling on startup is usually the same thing. Bear in mind though that I have not encountered it being audbile outside the car... at least not significantly (maybe I didn't get out of the car fast enough).
I would get concerned about a noise that's loud enough to hear from outside the car... but anything from inside is probably relatively benign.
Hope this helps put someones mind at ease.
Ich bin ein SVXer wieder
My Rides:
Red 1996 SVX LSi (Saffron)
2007 Yamaha FJR1300 (Kaitlin)
Previously owned; green '95 L AWD (sold), black/pearlie '94 LSi (too many problems), Polo Green '96 SVX LSi (apparently notThe end of an era)
Member #2 in the Yahoo! club, been here since the beta-testing days. In dire need of a cheaper hobby.
Old 09-13-2007, 10:39 AM
AlcyoneDaze's Avatar
AlcyoneDaze AlcyoneDaze is offline
<-- custom hood ornament
Send a message via AIM to AlcyoneDaze Send a message via Yahoo to AlcyoneDaze
I've been hearing it inside the car and outside the car if the hood is opened when im shutting her down... just assumed it was coolant/fuel/freon settling down for the night
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L
Donating Forum Member In Good Standing
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 09-13-2007, 03:56 PM
Yeah, that's sort of the sound I was describing. It may be nothing... as I said every Subaru I've ever owned did this and I never had a problem.
Hope that helps ease your mind a little.
My Rides:
