EDM headlights
There must be a few SVXs in Europe/UK that are in wreckers?.
I've picked up the EDM set of headlights & the adjustable tilt switch. What I require is the mating connectors for all 3 connectors. Behind each of the headlights there will be 6-pin connectors. In the center consolde area there will also be a similar connector. I require all 3 connectors (plus a bit of wiring). Just in the process of adding the fog lights into these units. Thanks Steve in New Zealand surteess@xtra.co.nz
Re: EDM headlights
Re: EDM headlights
adjustment switch
Re: EDM headlights
Rear deck blower. How much? PM $$$$ amount
Re: EDM headlights
Sorry don't have one for sale (but might have one later in the year from a JDM wreck coming in to NZ).
