Throttle Body set screw
Mine just broke...
Hope it doesn't matter! Mike mentioned that he has had to close his butterfly valves a bit to make it idle better, but I don't remember if he said he closed them all the way. Anyways, I am ordering a replacement screw, and hoping it runs till then. It always something I'm thinking that because the cams have more duration, they take in enough air with the flow through the IACV, and so closing the butterflies at idle will help adjust the air intake back to a normal amount.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted Last edited by Cam; 04-02-2011 at 01:44 PM. |
