ABS light staying on and running
so i was sitting in a drive through and my ABS light came on. i shut the car off and restarted it. the light came back on. so i drove home and parked the car. i heard a weird sound and opened the hood and there is a sound coming from the ABS system under the hood. any ideas at all what is going on
Re: ABS light staying on and running
The relay is stuck, tap the top of the black box marked ABS. If you want a more permanent fix, remove the screw and you'll see 2 relays. Replace the one making the noise.
thanks a lot that worked!!!!!
Glad I could help.
This happened to me yesterday, and first thing I checked was the relay, found which one was making the noise then took it out. Unfortunately autozone near me does not carry them. So I drove around without the relay to and from the parst store, then when I got home I reinserted the old relay and it stopped buzzing and the ABS light did not come on when I restarted it. I'm hoping it's just a fluke and not gonna come back. But jus in case I'll prob order another relay.
I found this link accidentally, and Hope someone will find it useful, it has the updated modified relay part number. (see below, copied and paste version) http://svx-iw.com/svxiw/article/print.php?article=16 ____________________________________ ABS Relay Sticking Author: Subaru NUMBER: 06-28-96 DATE: 06-11-96 APPLICABILITY: LEGACY, IMPREZA AND SVX EQUIPPED WITH ABS BRAKES SUBJECT: ABS RELAY STICKING Should you encounter the following condition(s) please follow the trouble shooting chart as shown. The ABS Hydraulic Unit Motor continues to run and/or buzz when the ignition key is turned to the off position. The ABS warning light comes on and a trouble code "52" for a faulty hydraulic motor and/or motor relay is stored in memory. Note: It is possible for this condition to occur intermittently. Under these conditions the symptoms may not always be duplicated. Troubleshooting Steps: Check if the ABS Hydraulic Unit Motor is running or if you can duplicate the condition. If the Hydraulic Unit Motor is running, does it continue to run with the key in the off position? Confirm the trouble code, if any, and trouble shoot according to the Diagnostic Chart in the corresponding Service Manual. Replace the ABS Hydraulic Unit Motor Relay with a modified one. The new part number is 26735AA012. The new relay can be identified by a white line under the word Japan on the relay case. Note: Always check the part number supersession for any changes. If the wiring harness is at fault repair and/or replace as necessary. The new ABS Motor Relay has been changed in production begining with the following VIN's. Legacy (SIA built): Sedan: T*206647 S/W: T*308128 O/B: T*374098 SVX: T*100004 Impreza: Sedan: T*510065 S/W: T*810189 Coupe: T*410116 ___________________________________________
92 LS liquid silver ---> pics here:http://s36.photobucket.com/albums/e8...VX%20LS%20AWD/ |
Glad you were able to fix it but you should replace the relay as it will do to again
