Question - Rear boot light switch ?
OK - so my rear boot light burned out a while back and today I decided to swap it for an LED one (T12 type).
It slotted in without any issues (nice multi-led type), but noticed that the lamp cover had gone brittle and burned a hole in the semi-clear cover.....this got me thinking, so after I replaced the bulb, I closed the boot lid and I then opened the rear seat back ----- the light was still on in the boot. That is why I have had to change 2 batteries in 2 years!!!! So my question is - where is the on/off switch for the boot area light ??? TIA
Re: Question - Rear boot light switch ?
It may be a "Tilt" switch? in the trunk lid....though, no more than I use the light in the trunk, I'd just remove the bulb....but I always hated dealing with electrical issues.....
My '92 Claret had the same problem. The battery would go dead if I left the car for more than 5 or 6 hours. I found out one day when I put a pair of skis in the trunk with the seat down. I didn't do any trouble shooting, just removed the bulb.
There is some sort of tilt actuation switch or circuit here. I just tested it in my totally dark garage. I folded down the rear seat, pulled the trunk release lever, and lookedback into the trunk. No light. I went to the rear of the car and raised the unlocked trunk lid ever-so-slightly and the light came on. Lowered it down to almost locked and the light went out. We are only talking about lifting it up about 1/8" or so. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 01-09-2018 at 02:21 PM. |
SVXCESS,
thanks for the wiring diagram, I also have the same manual. Check out the last page of that manual ( manual is called section 6) - the last page shows a connector that is at the end of a wiring loom in the trunk, will check it out later today.
Mate it's in the lock section of the boot, where the boot locks down, have a look there, see a white lever, just press it.
Harvey, that makes a lot more sense. Thanks for your keen observations about things that just escape our attention. A simple spring-actuated device makes the most sense. Open circuit (no power) when the trunk lid is closed and a closed circuit to the lamp when the trunk is open. .
Yes John simple things, like the switch that operates the dome light, hidden in the door lock.
Now fixed - thanks again for the quick response.
Mine appeared to have gotten grease between the contacts causing continuous open circuit and hence light staying on.
Glad you got it sorted out!
That problem would have set off USA alarm systems. Ah one (very minor) advantage of the USA market alarm system.
"Peace is the flower of justice." |
