Tranny compatibility
Do you have a tranny compatibility list for SVX ?
preferable year and models of the car.
1992 Pearl White SVX LS-L 1991 "Red Baron" Grand Prix GTP 5spd 2002 Chevy TrailBlazer LT |
No answers?
Basically '98 and older transmissions without the spin on filter will work with the SVX. Most Subaru manual transmissions are SVX compatable.
David B. SVXipedia @ SVX-IW.COM -- SVX Information Warehouse 2.0 coming...eventually! Ebony 1992 SVX LS-L 5 spd Koni/GC Stebro 187k miles RIP (Rust In Pieces) 1993 SVX 5 spd Koni/GC Stebro Polyurethane bushings still available! Last edited by Earthworm; 05-30-2007 at 05:21 PM. |
I believe they were saying that the 05+ sti 6speed tranny is compatible, 99-2005 wrx is compatible, 94-99 legacy is compatible, and some era of the forester. My years are wrong probably but they should be close, perhaps someone can clarify... Keep in mind though, these all require modification including fabricated parts, fitting, etc, but quite a few folks have converted to manual trans, think there's around 50 on the network with a 5speed or 6speed.
Sorry for being a noob, but will any 98-older 4EAT tranny bolt in and work? I'm not looking for all the work of a manual swap and I'm looking at a car with a bad trans. Thanks.
Yeah, any trans will work and bolt up, but the SVX has a final drive ratio in the front and rear diff that is different than all other automatic Soobs. You'll need to match the rear diff to the new trans.
