Old 08-16-2012, 10:10 AM
clarkerussell clarkerussell is offline
Re: FINALLY finished my VC seals and TB swap... Looks like I need a rear main. $HIT
The engine is quite easy to pull as is just about any Subaru if you have a fair amount of mechanical experience. I'd also suggest buying the updated rear separator plate and new style screws in case that is leaking as well.
Yes, I was planning on just replacing everything back there
So, to do that I need the rear main oil seal and the separator plate, right?
Here are the parts I'm seeing at SubaruParts.com
11831 - Oil Separator $12.99
G78603 - Rear Main Seal $9.45
B50604 - Screws $0.83
Anything else?
Old 08-16-2012, 05:42 PM
Anything else?
Don't get the factory separator plate for the svx. Get the updated one. It's more expensive but is stamped steel. There are different bolts for it. Also, those numbers you have listed next to the parts are not the part numbers. Those are just the numbers that correspond to their diagram.
I'll get the part numbers for the plate and needed screws/bolts in a bit.
Old 08-16-2012, 06:47 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Does anyone know what the p/n is for the "updated seperator + bolts" is?
thanks
Steve in NZ
Old 08-16-2012, 07:18 PM
11831AA210 Cover Oil Separator $34.45 $27.28 $27.29
800406150 Bolt Socket $0.46 $0.30 $0.30 -this one comes with loctite and goes in the hole with the arrow on the seperator
800406140 Bolt Socket $0.46 $0.30 $1.50 -5 needed
Old 08-16-2012, 08:22 PM
Thanks, this is still a Subaru part, right?
Old 08-16-2012, 10:24 PM
Yep, all subaru part numbers.
Old 08-17-2012, 06:20 AM
Thanks,
So is there anything else that needs to be changed out while I'm there? I've done all the other seals on the front and sides...
