AC Leak
Hey guys
So today I finally got into charging the AC, and i found a big old leak Where the low side connects to the compressor...my friend poured some soapy water on it (bad idea?) so anybody knows what kind/size of O-ring it takes? Also, will it need to be vacuumed after I'm done replacing the o ring?
DIY FTW! 1993 SVX 25th Anniversary Edition @+142k -Rebuilt Tranny @135k -Regasketed Engine @140k -Enkei Raijin 18x8.5, with 255/35/18's @140k -BC racing Coilovers (From STI's) @142k |
Re: AC Leak
Taken from an answer given to me by Tapani
The drier numbers I don't have, but from memory they are 9,8x1,85mm (outer diam x thickness). You can also get a kit from Auto Zone , or I imagine other Auto parts stores, for about $5.00 that has 8 or 10 different sizes. Subaru has them in stock $1.85 each. Remove the old one and take it in. I can imagine they are the same across the Japanese market, Honda ! Toyota, Nissan etc. . If you take it to their parts dept they should be able to match it. It will be light green. Apply a small amount of AC compatable grease to it when installing it. My garage only charged me $99.00 for the repair ,checking and parts,evac. Dye. and gas charging and rechecing for leakes with sniffer and UV light. If you buy the gas with charging unit, + one additional can it will run u about $16.00 a 12 oz can and $20.00 for the gage unit. Takes 18 oz. You didn't say what year the car was. Or what gas it has. This is all based on 134a not the old 12 Reason I know I did it myself the first time and bought all the stuff to save a $ . It leaked and then had it done professionally and he will fix it free if it leakes within 60 days. Last edited by Conn SVX; 06-13-2012 at 06:46 AM. |
Re: AC Leak
A pressure test with nitrogen is good idea to start with. And yes, you absolutely need to evacuate the system prior to recharging it. Tapani |
Re: AC Leak
Also, big lots was selling r134a for $9 (12oz)...bought a few Quote:
anybody knows a place to rent one? or to get it evacuated for like $20?
Re: AC Leak
At $9.00 a can use the 134a. O ring looks wrong but dim. Sound about right .
Re: AC Leak
If you have a 5hp or larger compressor, you can get a venturi vacuum pump from harbor Freight for about$15 with a coupon. They also have a gauge set for about $38 with coupon. Nitrogen pressure test is by far best, but if system holds vacuum it may be good...certainly, if it doesn't hold vacuum it has a leak.
Try to use a florescent dye, if it has a leak it will be easier to find.
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
Re: AC Leak
I don't wanna pay for all of those, i mean i'm in SF, and AC is required for a month or so...so small leak would be fine since i can recharge it next year, and fix it when rob a bank!!!
