Thread Tools | Display Modes |
FINALLY finished my VC seals and TB swap... Looks like I need a rear main. $HIT!!!!
OK, so I finally got to crank my car up after replacing the VC gaskets, VC washers, Cam seals, Oil pump seals, Timing Belt, Water pump, pulleys, etc.
After letting it run for 15 minutes there were ZERO leaks on the parts I just replaced.. EXCELLENT. I went under the car and noticed a tiny drop of oil dripping down onto the cross member near the steering rack. Upon further inspection, I saw that it was coming from above the rear of the oil pan, slightly to the right of dead center. This was FRESH oil, not runoff from the old problem, and it was slow but continuous. Crap. Just when I thought I was done. I don't know if I'm capable of changing the rear main seal and/or seperator plate. I'm assuming that the transmission needs to be dropped to get to it, right? How much more difficult is this project than what I just completed? How much would a shop charge to do this? Thanks. Clarke |
Re: FINALLY finished my VC seals and TB swap... Looks like I need a rear main. $HIT
It's a bit more difficult, but if you have access to a lift or a cherry picker, not too bad of a job in all honesty.
A shop will charge more than it's worth IMO... |
That's a pisser considering all of the other stuff you replaced would have been very simple with the engine out!
I would not bother fixing that leak unless the transmission was coming out for another reason.
So are the options to pull the engine or drop the tranny? If so, can the tranny be dropped with the car on jack stands, or do you really need a lift?
Now, the next question is if it's better to pull the engine now, or just do the tranny drop method at this point... |
I've replaced a tranny on jackstands in my garage. It's been many years, but I remember having the jackstands on top of blocks just to get it all high enough to get the tranny out.
Removing the tranny takes less in terms of junk removal (wires, hoses, etc. ) But it is tough without a lift. Removing it from underneath on jackstands kinda sucks. Removing the engine is pretty simple if you have a cherry picker. Once you have all the hoses and wires loose it pulls right out. A folding cherry picker isn't too expensive from harbor freight or northern tools. If you ask around you might even find a friend has one in their garage. Plus, with that engine out you have all kinds of room to clean it, change plugs, etc. Personally, if my rear main was leaking I'd pull the engine. You might get a different answer from someone who has done a few tranny swaps and is good at it. I've only pulled the engine once and I've only pulled the tranny once and to me pulling the engine sucked a lot less than the tranny.
So one of the Subaru Dealers in Charlotte have quoted me $600-$650 to do the repair. Damn... I was hoping for about $400.
I can't decide what to do. Are the two parts the Main oil seal and the Oil seperator cover, or are there other items that need to be replaced as well? |
