Old 08-10-2002, 08:38 PM
Ticallion
car audio - engine noise
Hey guys. I have an aftermarket system consisting of a clarion deck, two jbl amps, and a crossover. Two pairs of RCA's running to the back... when i plug in the Monster Wire RCA's (a lot heavier shielding than my Stinger hyper series), i introduce engine noise into the system. And i do mean engine noise. When the deck is muted, it is so damn loud!!! On an unrelated note, i upgraded to a different amp, so i know it's not the amp that's doing it. My guesses are either the crossover or the RCA's... but this didn't happen in my RX7. There was absolutely no engine noise in the system at all, and i had the same exact components. Is there anything that i could inspect? Perhaps a bad ground somewhere? Where? Should i re-do the grounding for the alternator?
Thanks guys
-Ross
Old 08-11-2002, 11:14 AM
Shadowyng's Avatar
Shadowyng Shadowyng is offline
Directionally Challenged
Send a message via AIM to Shadowyng
Let me ask this.. you didn't run the power wire to the amp next to the speaker cables going to and from the amp together.. The current draw might be bleeding through the lines.. When I did my install I ran the currnet along the left side of the car and then all the speaker cables anlong the right side of the car!
Old 08-11-2002, 11:29 AM
Ticallion
nope seperate sides. this is not my first install
Old 08-11-2002, 01:24 PM
Shadowyng's Avatar
Why does this happene after I posted the message took the car for a ride and I smell that funky electrial burning smell... ahhh boy.. the fron tspeaker is going wacky... tear down!!!! and I did that mistake of combining the wire the first time....
