SVXBot
Old 02-12-2019, 07:23 AM
Huskymaniac's Avatar
Uses the ignore feature
Re: I am ready to blow this car up. Won't start now.
All,
It is snowing again. My question is this. If the car is stuck in reverse, can a flat bed tow truck safely drag the car from the rear tow hooks onto the bed? I need to get this to a garage with a lift, I think.
Tony
1996 Subaru SVX LSi, 149,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 0W40 and 5W30 High Mileage Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, StopTech Cross Drilled Front and Rear Rotors, Akebono ProACT Brake Pads
2005 Acura RL, 128,XXX miles, Redline D4 ATF, Mobil 1 0W40 and 0W20 High Mileage Oil Blend
2009 Toyota Venza, 78,XXX, Mobil 1 5W30 High Mileage Oil
Old 02-12-2019, 12:00 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
I would say no, if its a 4WD then the center drive shaft needs to be disconnected before the front wheels are lifted (what about oil out of rear gearbox?).
1995 LSI, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow Polish bushes includes 15 min mod (90SH fitted), R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Added Gear Firm-Up unit (that I sell), Power TCU ROM & Power switch.
Old 02-12-2019, 01:47 PM
A slippery snow covered flat bed would work. The wheels would slid and no stress would be transmitted to the driveline. You could use dolleys also. Or being a skier I could suggest making some crud skis to put under the wheels.
1997 Bordeaux, 1992 Claret (parts car) 2011 BMW 535i GT Xdrive, 2006 Nissan X-Trail SE 4WD, 2012 Moto Guzzi Norge GT 8V, 1982 Honda Nighthawk 650
Old 02-12-2019, 03:09 PM
Trevor's Avatar
Trevor Trevor is offline
Originally Posted by Huskymaniac View Post
All,
Problem understood and appreciated.
Contact a reliable and trustworthy tow truck operator and discuss the problem with them.
In this part of the world operators are able to uplift locked and immobile cars including four wheel drives, without damage or a problem. Surely this applies your situation.
Trevor, New Zealand.
Old 02-12-2019, 04:33 PM
oab_au oab_au is offline
Tony as long as you are sure it is in reverse, and not park, without the engine running to produce line pressure, the whole box is in neutral. If it is in park the front wheels won’t turn.
One Arm Bloke.
Tell it like it is!
Old 02-12-2019, 06:59 PM
Trevor's Avatar
Provided that he has not already done so, after making sure that the hand brake is not engaged, Tony should check and confirm that all four wheels move freely, otherwise his fears regarding towing the car remain valid.
Old 02-12-2019, 09:25 PM
You mean other than the corrosion build up on the rotors probably sticking to the pads?
If the car is in reverse and I put a fuse in the fuse slot that disables AWD, will the AWD be disengaged?
Other than the dash lights saying it is in reverse, I guess I have no other way to know for sure that it is in reverse.
But, yeah, a good tow company has to be able to solve this.
Tony
Old 02-13-2019, 01:10 PM
SURTEESS's Avatar
Man am I glad we don't get snow where my SVX is - I could not stand all the issues that this guy is having.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
